WiFi issue after upgrade to ICS
Not applicable
Well, after I update to 4.04, there is a big problem for me, my xperia s can not obtain IP address automatically, even when I try to conncet to my router, my router DHCP function will not working anymore, and I must reset my router to make it restore the DHCP function, that is very strange. My router is TP-Link TD-W89741N.
Now, I set a static address on my xperia S, it looks working properly, but sometimes cannot connect to internet, so i still need a final solution, maybe next FW update can help me?
1 ACCEPTED SOLUTION
Johan
Master
Sounds strange, almost like the problem some users had with 2.3.3. So i suggest that you begin with updating/reinstalling your router firmware.
Let me know if that helps.
6 REPLIES 6
Johan
Master
Thommo
It's a known bug with the new firmware - Theres less power been given to the wi-fi and as such makes it hard for the phone to connect - I made a thread here when it 1st got released and XDA have confirmed that it is indeed a bug with the new ICS Firmware
Thommo
This is the list of Pro's Con's and Issues according to the Xperia S users of XDA running ICS
PROS.
1)Smooth UI
2)New Widgets
3)Facelock
4)Stylish Gallery App
5)Movie Player
6)Visualisation Walkman
7)Increase Performance
8)Normal ICS Features
I.e Data usage, Reordered settings, Task killer, Keyboard
CONS.
1)Gallery App Has No Folder Sort
2)Walkman Icons Are Ugly (Personal Preference)
3)No New Functionality In Camera & Its Still Noisy
4)Low RAM
ISSUES
1)WiFi Signal Drops
2)BT Audio Lags
3)Laggy UI & Lockscreen (For Some Users)
4)Facebook Old Looks
5)Bravia Engine Not Working In Gallery
GUL
I am facing same problems wifi signal very poor. navigation not working after update
Thommo
Yeah my CoPilot stopped working and gave me errors so I ended up having to downgrade back to GingerBread
Not applicable
Yes, I update my Wireless Router Firmware, and the DHCP issue is sloved. now my Xperia S can obtain IP adress automatically. Thanks a lot!
