how do I identify is it the arc S is original, by matching the box IME with phone after key is *#06# only?
or can I know from the IME number?
just connect it to the computer and download the pc companion.. ( a pop up will appear when you connect it to your pc , downlod it )
if it is recognied by the pc companion that means its original..
what do you mean, is original?
do you suspect your phone is a fake?
I mean how to determine is the phone is original sory ericsson phone or is a AP(Approved Product)
That means in the sense this is the way to identify wether my phone is Arc or Arc S. Thanks for the suggesion slimshaddy. Because according to SE Arc and Arc S are visually the same and only the processor and OS is upgraded in Arc S. So thanx again.
no problemo :smileygrin:
