When phone gets stuck
gareebnavas
I'm going to buy an experia p and i would like to know if the phone got stuck or hang, since the battery is not removable is there any other way to restart the phone immedietly? and if got any problem with the battery is it changable at the service center?
1 ACCEPTED SOLUTION
Nabeel
Master
ryan515 is correct
Press and hold Power Button and Volume Up button at the same time
5 Seconds > Restart Phone
10 Seconds > Shutdown Phone
And yes , you can get the battery replaced at service center Slightly_smiling_Face
5 REPLIES 5
Raja22223
Contributor
Hi Gareebnavas, I hope u wont face all the issues as mentioned above by u..
In my experience, I didn't face any Hanging issue to my phone,Unless u use the mobile with LOT of Applications
U r saying that Instant Reboot with Battery removing which is not advaicable, For that Power button is there.
And Finally, Service will be there for you if u face Any problems.
gareebnavas
I've heard many people saying about their phone that their phone gets hang and they wait untill the battery is empty and nothing else to do to restart the phone since we can't remove and re-insert it.
Since experia p is an android phone obviously we add many apps and there are possibilties to get the phone stuck. I will be happy if there is a way to get the phone restarted instantly. Is it possible to restart the phone by pressing power button and volume up botton together in such cases?
Not applicable
There is always a solution.:
when this occurs .
just press and holdthe  volume down key and power button at the same time.
ryan515
Contributor
i think it's volume up + power button..
Nabeel
Master
ryan515 is correct
