Restart problem after try to upgrade ICS
Not applicable
Now, my xperia s had many  time of restart problems
after I try many tIme to upgrade ICS with pc companIon and update servIce. It failed every time.
the problem wIll be occur  after I push power button f or monItor closIng.
Could you  help me to fix this problem?
1 ACCEPTED SOLUTION
Uliwooly
Remove the micro SIM card and turn it on w/o it
6 REPLIES 6
Uliwooly
install SUS on your PC -> restart your PC -> run it
once it ask you to connect on flashmode connect your phone and press and hold the power button & volume up (hold it for 5-10 seconds)
Uliwooly
Not applicable
I was Install ICS by flashtool.
The problem stIll not fIxed at my phone.
Could anyone  please recommend to solve thIs problem?
Uliwooly
Not applicable
Last nIght, I reseted my phone by power & Volume+ Button.
Afterthat, I cloesd It agaIn. Then, I removed mIcro sIm Iut from slot and put It again.
Now, the problem Had been fIxIng It for +8 hours.
Thank you for your help Slightly_smiling_Face
Uliwooly
anytime
