Problem with Contract List
Zayed
Hi Aliens Slightly_smiling_Face
I am from UAE and using Xperia S, Its very good experience being using this smart phone.... I have an issue after sync my contct list I can see all the contacts of a same person saved in my moblie i.e. mob #, FB ID, Linkedin ID, Twitter, Skype etc.... even it saved with the exactly same name but still showing saperatly according to related above mentioned IDs..... these all contact numbers and IDs should be shown combined under one name after Sync.....
does anybody faced this prob and have any solution kindly share.... thanks....
1 ACCEPTED SOLUTION
getandrew
Hi Zayed,
I got your point goto to contact and long press a particular contact you will get a list asking for edit contact,delete contact, add to favorties and link contact, where you press link contact and it will show your contact list which you need to link so select the desired contacts and link it has single contact Slightly_smiling_Face
With Regards,
Andrew.
6 REPLIES 6
getandrew
Hi Zayed,
In contact click menu where you can see filter, in that you can customize.
Regards,
Andrew
Zayed
Dear Andrew,
Thanks for the reply.... but I could not find my solution.... may be I can explain by an example.
I have a friend Faisal who has multiple IDs and contact Nos in my phone which is stored saperatly and showing seperat in my contact list for Skype, FB, Linkedin, Cell No. twitter etc... I want to make his contect list combined under one name... if i search only Faisal name and can se all the detail in one list....
I hope to understand my query....
thanks again for the response..
Thank you
Regards,
Zayed
getandrew
Hi Zayed,
With Regards,
Andrew.
Zayed
Thank you Andrew.. it was really helpful :smileygrin: is there no other option to do at 1 time or I have to one by one?
getandrew
Hi zayed,
You can use thrid party apps like contact analyzer but better not to go with any third party software, anyhow spend some time with your new mobile Slightly_smiling_Face organzing for 1st time. If you need any more help jus PM me.
With Regards,
Vivian Andrew
Zayed
Thank you 😉
