ICS questions...
bogdann
ICS questions...
Hy guys i updated my phone to 4.0.4 and i was wondering
When i bought my phone on the box it says android 4.0 upgradeable ( At what versions locks ? )
Here is a link with a different look of ICS...how can upgrade to that version to look like that ? ( please watch the video )
4.0.4 AOSP
http://www.youtube.com/watch?v=Bh9r0A9OWug&feature=related
1 ACCEPTED SOLUTION
profile.country.PH.title
MarlonUk1
Its a custom ICS rom, and you have to be knowledgeable enough for that to be installed in your phone, you have to know about rooting, unlocking bootloader and stuff, and I think it involves changing the kernel (which could be quite dangerous), if you want you can use some apps that changes the look and feel of your devices instead of changing the whole ROM, try searching the market of apps like golauncher. Slightly_smiling_Face
15 REPLIES 15
DeGraaff
Contributor
It's in the description of that video...
bogdann
I don`t understand...
MarlonUk1
bogdann
I understand now, the best soft is from sony that i have and use.
question1 for nolramlb > Can install Android Honeycomb on my Xperia ? ( IF yes...how )
question2 > I think the ICS is draining a lot the battery...visible and how to downgrade to gingerbread...
Thanks a lot.
MarlonUk1
1.)No, android honeycomb is exclusive for tablets..
2.) If you still have a backup of your firmware you can downgrade it by yourself: follow instuctions here: http://talk.sonymobile.com/message/198355#198355#198355
If not, you can bring your device to a sony service center and inquire about downgrading, they can downgrade it themselves.. Slightly_smiling_Face
DeGraaff
Contributor
Or if no backup he can just use wotanserver, the result is just as official and he won't have to miss his phone for 2 or 3 weeks. Winking_Face
MarlonUk1
i dunno why it varies among countries but when I had  consulted with sony center here (philippines), they say they can do it just hours. Thinking_Face
bogdann
So if i don`t have no backup...i think i don`t have ... if there is weere i can find it...if not isn`t any way to do this operation home instead of sending the phone to service.. ?
MarlonUk1
See the back up section: http://talk.sonymobile.com/thread/38251 this should have been done before you upgrade to ICS.
you can try DeGraaff's suggestion, but you have to pay Slightly_smiling_Face http://www.wotanserver.com/en
