How to charge neo battery correctly?
Not applicable
I want to know about some good tips to charge neo battery correctly. I don't know should i charge my phone to 100%  or less. When should i charge it?
If u have some good tips to keep the battery healthy, it would be great.
Thanks alot.:smileyhappy:
1 ACCEPTED SOLUTION
jitudj
Hi Chikheang,
The good practice with the battery is always charge your battery for 100% and then use it unless it gets drained completely or left 5% only. Cause that way it will keep your battery healthy. This is the standard practice. And keeps battery life for long. I have seen that people keep on connected their phone to the AC adapter or charger even when charging is not required. With this false practice the semi conductor or thermal components in battery becomes useless and after that you will find that the capacity of holding the charge for your battery has been reduced. The same thing works with the batteries of your laptops and other equipments. Hence the recomended practice is always charge full---- then drain it completely--- then recharge it again. You will get good life of battery for sure.
This is something i have tested and i am following.. Slightly_smiling_Face
Enjoy your Sony mobile phone!!! Slightly_smiling_Face
3 REPLIES 3
Uliwooly
you can charge it a little bit or all the way it won't affect your battery life
Uliwooly
check this out
http://en.wikipedia.org/wiki/Lithium-ion_battery#Prolonging_battery_pack_life
jitudj
Hi Chikheang,
