GPS signal problem
GUL
GPS signal problem
After update to ICS GPS signal is very poor. and Navigation is not working. Before update it is working well.
SONY create a problem for us????????????????
1 ACCEPTED SOLUTION
Nabeel
Master
Go to settings > location > Mark all the 3 options
See if GPS somehow improved if not
TRy to repair your software
________________________________________________________________
Backup everything as it will erase all data on phone (sms, contacts,apps)
PCC (PC COMPANION) – Repair your software with this .First do the setup without connecting your mobile to pc.(only connect when you are asked to).
Do it as follow >> PCC > SUPPORT ZONE> SOFTWARE UPDATE> REPAIR SOFTWARE (written with blue)
PC Companion http://www.sonymobile.com/global-en/tools/pc-companion/
1 REPLY 1
Nabeel
Master
