data monitor/apps
Not applicable
data monitor/apps
two queries for help please:
1. in the userguide there is mention of a data monitor. Anybody know where this is??
2. how can I get some rid ofsome of the apps/widgets i don't need. I can get them in the dustbin but they don't stay there!!
1 ACCEPTED SOLUTION
Nabeel
Master
Tap and hold on homescreen > widgets > data monitor
To remove widgets > press and hold on a widget > drag it to the bin
7 REPLIES 7
Not applicable
Installed Onavo Count App - feels & performs good.
Will really appreciate a response about native data monitor, for us un-initiated... Slightly_smiling_Face
Nabeel
Master
srcrow
1- I allready got a diferent app but the native is this one: https://play.google.com/store/apps/details?id=com.sonyericsson.android.datamonitor&feature=search_re...
2- You can`t unless you flash a new rom.
Nabeel
Master
Oops, :smileyblush:
romeoa21 you were asking to remove few preinstalled apps ?
that's not possible until you root your phone
Not applicable
thanks
rooting the phone sounds a bit drastic!
Not applicable
thanks
have now installed my provider's own app
flash a new rom -is that the same as rooting the phone?
xperiaU
hey i dont have this widget.
i have a 'traffic' widget.
is this the same?
