hi guys,
can you help me, whenever i closed main camera screen and open images from camera, i heared a sound like 'tick'
is this normal?
its too loud , i know its a mechanical thing , it will create some sound , but as i said it does not always sound like that....
when i closed my camera i hear a "tick" sound when my ear was too closed with my mobile.
i try also sample of mobile in the service center they are the same. when you are in a crowd area you will not hear anything.
but if you here a loud sound, try to ask them why it was happening.
well i dont want that morons to open up the phone and fuck the internal things
i can live with this sound..however i will wait for the ics update and then if the problem remains , i'll head to a service centre
hello! i'm new here and i was looking for some answers to the ticking sound the phone makes when you close the main screen of the camera. the thread has been labeled answered but i think the answer is a bit incomplete. anyway, i never heard any ticking sound before until very recently --- like a few hours ago. i'm using android version 4.0.3 // build number 4.1.a.0.562. i read what uliwooly said that it's normal. but if it were, then the sound should have already been there when i first bought my phone. there's a new update available but i haven't updated my phone yet because i may lose some data like last time when i updated to ICS from gingerbread so i'm sticking to my current version for now. i was wondering if the issue has been fixed after updating to the latest version. i'm also wondering what's causing this ticking sound. because if it's a hardware problem and there ought to be moving parts inside, and if this thing keeps on ticking, it may eventually wear off certain moving parts. i want to take my phone to the service center but if there's a solution to this issue without going there i'd welcome it. also, as a side note, my phone no longer detects my 32gb micro sd card. i'm not sure if there's a connection between the two. i still need to look for an extra micro sd card to make sure that the prob with my memory and not the phone. btw, i noticed the ticking sound appeared when this thing happened.
you can take your phone to a sony repair center to get it checked
unrelated topic, if you have some time please check this thread
i was afraid somebody would say this. thanks anyway.
