Closed main camera screen has a sound
Not applicable
hi guys,
can you help me, whenever i closed main camera screen and open images from camera, i heared a sound like 'tick'
is this normal?
1 ACCEPTED SOLUTION
Uliwooly
Yes indeed that's normal
Btw go to settings -> about phone
which
android version
and
build number do you have?
the latest is 2.3.4 build number 4.0.2.A.0.62
15 REPLIES 15
Uliwooly
which
android version
and
Uliwooly
if you don't have that update, you should, it solves some issues like constant reboots
1) backup everything then
2) use SEUS to update your phone
2)
Update Service (SEUS)
http://dl-www.sonyericsson.com/cws/download/1/110/61/1309763183/Update_Service_Setup-2.11.7.13.exe
1) Make sure you backup everything
Settings -> privacy -> Back up my data and Automatic restore should be selected
and also
Use one of these links to download the
Backup & Restore app
http://forum.xda-developers.com/showthread.php?t=1193802
or
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apk
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apkor
http://www.mediafire.com/?1n07llajeaoo03y
How to install it
You need to
go to settings -> applications -> check unknown sources
download IO File Manager
https://market.android.com/details?id=org.openintents.filemanager&feature=search_result
download the backup & restore app, transfer it to your SD card, use OI file manager to find it -> tap on it -> install it
Contacts
just to play it safe sync your contacts w/ google if you haven't already
open your phonebook
press MENU button -> tap on Send Contacts -> select all -> send it to your email
on your computer
-> download the file -> go to your gmail -> click on contacts -> click on more actions -> on the drop down menu click on "import" -> choose the file -> and click import
Apps
Don't worry so much about backing up your apps
on your computer go to
market.android.com -> log in -> click on My Library -> and send all your apps to your phone
market my library.JPGmarket my library 02.JPGmarket my library 03.JPGmarket my library 04.JPG
SMS/MMS
if you don't want to use the backup & restore app then
Install "backup SMS" to back up your SMS and MMS to your Gmail
https://market.android.com/details?id=com.zegoggles.smssync&feature=search_result
or your SMS use
"backup & restore SMS"
https://market.android.com/details?id=com.riteshsahu.SMSBackupRestore&feature=search_result
or for your MMS use "Save MMS"
https://market.android.com/details?id=com.schwimmer.android.mmsextract&feature=search_result
Call Logs
And for call logs this is great
https://market.android.com/details?id=com.yang.android.ansta
My Phone Explorer
https://market.android.com/details?id=com.fjsoft.myphoneexplorer.client&hl=en
http://www.fjsoft.at/en/
Other methods on how to install the Backup & Restore app and/or other apps that are stored on your SD card
1st Method
How to install it
You need to
download the app on your computer, transfer it to your SD card, use OI file manager to find it -> tap on it -> install it
2nd method
download the apk on your computer, send it to yourself through email, make sure you send it to your Gmail
now on your phone
wait for the email, once  you get the email, open it, and instead of downloading the attachment it will allow you to install it, voila, done
3rd Method
BOX and upload the apks from any computer
install the App on your phone -> open BOX -> tap on the app -> install it
4th Method by far the easiest
an even Easier alternative
download the app, transfer it to your SD card
Download Apk Manager
https://market.android.com/details?id=com.magmamobile.app.apkinstaller&hl=en
open "Apk Manager" and voila select the apps that you wan't to install
Uliwooly
If you want to manually update your phone
Xperia Neo V MT11i 2.3.4  update 4.0.2.A.0.62
http://talk.sonyericsson.com/thread/30938
Xperia Neo MT15i 2.3.4 minor update 4.0.2.A.0.62
http://talk.sonyericsson.com/thread/30193
Xperia Pro MK16i/a 2.3.4 update 4.0.2.A.0.58
http://talk.sonyericsson.com/thread/29687
Not applicable
Yes, this is the version of my phone "latest is 2.3.4 build number 4.0.2.A.0.62"
Uliwooly
ok, just checking, at least you can use the suggestions bellow to backup your phone, in case something happen Dizzy_Face
Not applicable
ok, thank you.
but it is normal right?
Uliwooly
yeah
slimshaddy
Hero
i have the sme problem , many other users also..
uliwooly - its not normal Slightly_frowning_Face
i'm 100% sure that khien does not faces this problem every time he exit , its about 70% of the times..
Uliwooly
I hear something with my Arc, Play and X10 and other Xperias I've test, or is it a different sound?
