Auto silence
nasfannasar
Auto silence
After I updated my Arc S to ICS 4.0.3 from GB the phone automatically goes to the silence mode sometimes. Also vice versa occurs. Any solution please?
1 ACCEPTED SOLUTION
Nabeel
Master
It could be due to third party app interfering
Check apps such as antivirus, task killers ( same types ) and revise their settings
Explore these threads of similar type
  3G Data traffic keeps switching back on
     My Xperia X8 display light automatically turns on, even if not in use
     XPERIA S, wifi auto switch-on
     Display keeps turning on.
    Fail to Save Default Actions
     Screen Blinks every 10 secs after locking in Xperia Neo V
     Display keep turning on/off automatically
     Live with Walkman screen turns on suddenly
If they don't help then repair your phone
________________________________________________________________
Backup everything as it will erase all data on phone (sms, contacts,apps)
Update/Repair your phone via PCC or SUS
PCC (PC COMPANION) – Repair your software with this .First do the setup without connecting your mobile to pc.(only connect when you are asked to).
Do it as follow >> PCC > SUPPORT ZONE> SOFTWARE UPDATE> REPAIR SOFTWARE (written with blue)
PC Companion http://www.sonymobile.com/global-en/tools/pc-companion/
SUS ( Sony Update Service)  ... download and install it on pc and follow the on-screen instructions http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
                  or
http://www.sonymobile.com/global-en/tools/update-service/
Both the links are same
1 REPLY 1
Nabeel
Master
                  or
