yesterday i updated my sony xperia L 4.1.2 to 4.2.2 till 24 hours it works fine suddenly it started restarting when i used to open chrome please help out
hello buddy i did repair to my Xperia L nearby 4 times again n again am getting same issue restarting.. repair sollution works for oly one day after its turn in to same issue restarting again n again..
The actual problem is with chrome. The following method worked for me. Go into Settings->Apps->Chrome then click the Disable button. It ll show some dialog press ok and wait for it to get disabled. Install any other good browser available in the playstore. I did this this before 10 days and i am not experiencing this issue anymore
My phone turns itself off and on the past hour. Nothing helps....
HELP?!
Sony update service does not help you?
Thanks ,,,it worked
I am glad it worked.
repair your phone with SUS does not solve the problem. also my phone take eons to connect to 3g network and often not even connect. i have to restatrt the phone to make it connect.....
what can I do?
wish i could never done the upgrade to
15.3.A.1.14
i have the phone only since 2 days an having an aweful Xperience
Have you tried redownloading internet settings?
