It could be a firmware issue but also a power supply/socket issue
So you can try, if not already done
- Another wall socket
- Another PSU (if you have it)
- Charge your phone from a PC/Laptop with a USB cable
- Check also if phone overheats a lot (not quite warm) during charging
Anyway I had the same issue with my Xperia L and was solved with last firmware update
Yes that happens with mine too,, I cannot unlock the screen pattern while its charging. I bought it a week back.
Same issue connecting to a computer?
Did you install the last firmware update?
You can load your phone in safe mode and check if issue is the same
You can check warranty policy for your country on sony website (Manual section of Xperia L)
Anyway accessories drop in the box with the phone (like battery, hearphone and power supply) are covered for 6/12 months
