mailing problem
Azad
mailing problem
I can't send mail from my xperia l, though I can recive mail. Whenever I try to send a mail connection error pops up. Please help me
1 ACCEPTED SOLUTION
Azad
In both email as well as gmail I m facing the same problem
10 REPLIES 10
Uliwooly
Is it through Gmail or another Email app
Azad
Azad
Sorry there's correction in email only I am facing this problem
Uliwooly
perhaps there are issues with your data plan, does this happen with both data plan on and wifi?
Azad
In both cases I get same response.
Azad
Can it be due to some settings which I have to change? It occurs only in case of email
Uliwooly
This is quite odd, have you changed any background data setting?
Azad
No, it is not changed. The problem is with yahoomail only. Gmail is working well
Azad
I have removed the account and then activated it again but still it is showing connection problem while sending the mail
