Hello,
I am not update to use enter key (↵), either in email nor in messages. Please help... This problem occur after my first update of software. Earlier it was working fine.
Settings-app-all-xperia keyboard,clear data,restart the phone.
You are welcome.
Xperia L - Jellybean 4.2.2 (15.3.A.0.26, 15.3.A.1.12, 15.3.A.1.14). While selecting other options in Xepria Keyboard ->Text Input Settings -> Word Suggestions, the Return / Enter key works fine. But the Return / Enter key functionality in the option: 'I don't want any help when writing, not even suggestions', does not work at all. Factory reset did not solve it. Also Settings-app-all-xperia keyboard,clear data,restart the phone solution did not work either.
Any ideas.....!!
I agree with you Akhanb even it works with Phonepad keyboard, it's not workin for Full keyboard. While its in potrait-phonepad mode the enter key works fine. Once landscape full keyboard come, new line isn't working.
I just bought xperia l yesterday, I think all fine. after the firmware update the phone firmware to a previous firmware 15.3.A.1.14 after 15.0.A.2.17 phone, the enter key on the keyboard xperia does not work if I turn off word suggestion, SONY please help me.
I really like this phone,
the latter for SONY whether xperia L Kitkat and get updates when?
thank you sony, and please do not disappoint us as users of Xperia...
thanks for your reply.
I've tried it.
setting-apps-all-xperia keyboard-clear data and restart
but the problem was still not resolved.
if I use "word suggestions" can enter button works, but when I disable "word suggestions" enter button return does not work.
whether it includes a firmware bug problem 15.3.A.1.14?
please help me !
thank you.
