Battery indicator
Marius2
Battery indicator
I took of my battery and let it out for 1 night, and then everything is ok, but before, near the battery indicator was a battery percent, now its gone and i have no idea how to put it back. Please help
1 ACCEPTED SOLUTION
jochristianto
Please try this:
  1. Open Settings
  2. Select Power Management
  3. Scroll down, then check the Status Bar Information.
Now you problem is solved.
6 REPLIES 6
jochristianto
Please try this:
  1. Open Settings
Marius2
Thank you very much. it was checked but i unchecked it and then check it away and now its working. thanks
jochristianto
I don't know why, but as long as it is working fine, I think it is okay.
You're welcome anyway.
Marius2
I have one more question:
When i move a song from a folder to another, it sometimes give me 2 songs in walkman app, one is working but the other has 0:00 seconds and i cant remove it neither from the walkman app, nor from the file manager.
jochristianto
I don't know why that is happening to you. But I think you can try to remove it from your computer. Anyway, please check on the existing thread about that, and/or create another thread with different subject, so the other can help you correctly.
sanu6069
Dear friend,
    I have the same issue on my xperia z1, its not showing any battery indication on the screen. Even the charging time also.
I checked over the power management, but noting for the indicators
So please answer me???? Face_with_Thermometer
