I am new to blueray players. What do I need to use BD LIVE ?? Is it a usb stick or drive. Some call them by other names. What does one look like. Whats the average cost ? And what amount of mb`s will I need to use one.
Hi you would need a USB 1GB or greater pen drive/stick. this needs to fit in the socket on the rear of the player, if it is not BD Live ready, really depends on which model you have. costs can be from as little as £1 upwards depending where buy.
