Trying to get Sony BDP S380 to use Iomega Mini max HDDs via fornt USB port.
Getting "not supported" Have tried formating as FAT 32, exFAT and NTFS - no change
Can the S380 read Mac formats?
Hello,
I don't think the S380 can read any Mac format.
I think this HDD has Iomega Protection Suite built in
Sony recommend Westerdigital HDD with power supply.
You may try reformat once again using windows to FAT32, is the best format
