Since the digital switch-over I can no longer record future programmes.I can record the programme I am watching but what is the point of that? I have got a Sony RDR- GX210. dvd recorder and a Sony digital television KD-28DL11U.I have tried recording using the Electronic Programme Guide but it does not record. Before the switch-over I could just press TIMER button on the dvd remote and it would record.I can't do it this way now because you need to have INPUT SELECT on LINE1 and then you cannot specify which programme you want to record but ,as I say, using the EPG doesn't work either.HELP PLEASE it's driving me mad!
I don't have the same recorder but should still be able to record programmes in advance. Obviously if you are looking for a smart function you should have a digital tuner and so you have to change your recorder...
This should be the right procedure:
Obviously you have to be careful in programming (if possible) or setting manually the attached decoder to be switched on and on the desired tv channel at the time the recorder will start the recording. It's annoying, but as I said the only alternative is to change the recorder...
