System
KDL46W905A TV + BDPS1500 3d Player + HT-IS100 Home theatre System.
Issue How to connect 3d player to HT-IS100 and maintain surround sound as it appears I have to connect 3d Player direct to TV to active 3D signal
Hi there
You have two options to connect these devices
1st Way:
2nd Way:
Also turn on Bravia Sync on all devices for both options.
Cheers
Hi there
1st Way:
2nd Way:
Cheers
Thank you. Used Option 2 all OK.
