I can se on the telivision thatmy serveris found, but it cannot connect . The blueray player has a wired connection (lan)to the HP Mediasmart ex490. On my pc it is no problem to wiew photos and listen to music.
I get message Link connection status: succeded
Provisioning server connection: Failed
I can se on the televisionthe nameof my server:HPSERVER
Does anyone have a clue to get on with?
Looks like there is a firewall working behind the problem which make some server ports not open for communication.
Give a try to Serviio as it configure the pc ports in easier way , temporary switch off any firewall you have
http://www.serviio.org/download
kindly let me know the result
