HELP,No sound from Blue-ray BDP-S380 to DVD Home theatre system DAV-DZ830W using optical cable.Limited with HDMI points so only using the HDMI from Blue-ray to TV,picture and tv sbut love to use surround sound as well via optical,anyone????
gazrob
HELP,No sound from DVD Home Theatre system DAV-DZ830W from Blue-ray BDP-S380 using optical cable.Limited with HDMI connections,only the one from Blue ray to TV,great picture ans TV sound but would love the surround sound from Theatre.Need a step guide to settings and selection on both systems if poss.Connection of optical at blue ray is jack point ,connection at Theatre is square,the cable provides both..Be very greatful to anybody,
Thanks...Gary
1 ACCEPTED SOLUTION
Bravia55HX
get yourself a digital coaxial cable and connect the blu ray to the theater kit, leave the HDMI cable where it is, then in the menu of the blu ray player go to audio settings, scroll down to dolby digital (coaxial/optical) and set to dolby digital then set DTS to DTS and that should do it, dont know why you would think the optical connector at the blu ray is jack point, it should be the same as the theater kit.
if still unsure get the coaxial cable like the ones below.
http://www.amazon.co.uk/Crystal-Audio-CAD-DIGITAL-low-jitter-audiophile/dp/B004IO4IT8/ref=sr_1_39?ie...
or better still this one.
http://www.amazon.co.uk/Qed-I-QEDPDA-1-Performance-Digital-Coaxial/dp/B002GX0A8Q/ref=sr_1_10?ie=UTF8...
its a little shorter but there are longer ones.
1 REPLY 1
Bravia55HX
