I have fitted a Lumos CPL together with slim MC UV filter and find that it appears to have affected focussing.
Has anyone else experienced problems with filters. Incidentally I also found a similar proble with the Fuji S1 but put it down to the need for a special fitment for filters.
Hi there,
Please see the following article here regarding attaching a filter.
Hopefully someone else in the community may be able to offer some advice on filters.
Best wishes,
Sean Mc
Hi there,
Best wishes,
Sean Mc
There is no thread on a sony HX400V
How do you fit a filter to it ?
Hi @Pikki70
Sony indicates the following filters to be compatible with the HX400V: http://support.d-imaging.sony.co.jp/www/cscs/accessories/compatibility.php?area=gb&lang=en&mdl=DSC-H...
The filter fits where the lens cap is when the camera isn't in use if that makes any sense.
Win_88
