XR-50X90J Media Buttons Won't work on TV remote
Drittz78
When I switch on my TV (XR-50X90J) sometimes the media and TV buttons on the remote don't work.  Other buttons like power and directions do work.  I have to power the TV off and on again and the buttons still won't work but after 2-3 minutes the TV soft resets and it works again.  TV is up to date.  Really fed up with the TV now.  Anyone had the same experience with their TV or a fix?
1 REPLY 1
TheMaze
You can try to unpair your remote control and pair again to test (check out this guide: https://helpguide.sony.net/tv/iaep1/v1/en/07_13.html)
Also, you may try to reset your remote control by removing the batteries, holding the power button for 3 seconds, then inserting new batteries.
Furthermore, you may update your remote software here: https://www.sony.co.uk/electronics/support/televisions-projectors-lcd-tvs-android-/xr-50x90j/article...
