Loss of sound
andytaz96
Loss of sound
I have a 4k tv, 55x8509. I turned on the tv this morning and it had no sound. I had to do a factory reset and the sound now works. If the sound goes again is there another way i can enable it without doing a factory reset? When will the firmware upgrade be avaliable in the uk and will this cure the no sound issue. Thanks.
0 REPLIES 0
