Bluetooth does not discover devices to pair.
enotsz
Hello.
I have a Sony Android Tv x80c (x8005c) that i recently acquired.
It seems that this tv is having problems discovering bluetooth devices, i recently purchased a gamepad that my tv is unable to find. The problem is not from the gamepad since i already tested it in my windows laptop, my android phone and on my ios phone, it worked without any problems. But my Sony Android Tv bluetooth seems to not find the device.
What other options do i have to try force the tv find my device? Is there any know issue that relates with this problem?
Best,
Tags (2)
30 REPLIES 30
mehboob1011
I have just got a new Samsung soundbar but my Sony Bravia does not pair with it.. any solutions please!
LightFoot
Specialist
Hi @mehboob1011   Would you please provide the model number of your TV. Not all TVs have the appropriate Blutooth Profile to pair to audio devices.
https://www.sony.co.uk/electronics/support/articles/00159290
mehboob1011
Hi.. Model number is KD55XF7596.
LightFoot
Specialist
Hi @mehboob1011   KD55XF7596 only supports Bluetooth mouse and keyboard. No audio (A2DP) support.
https://www.sony.co.uk/electronics/support/televisions-projectors-lcd-tvs-android-/kd-55xf7596/speci...
mehboob1011
That is really strange!! So that means I cannot connect any bluetood soundbar. There must be a way around it?
OLYMORTON
The answer is do not believe that in Sony language Bluetooth means
Bluetooth. I bought a Bluetooth enabled Sony for Bluetooth headphone use
and the Sony answer might just have said hard luck sucker
LightFoot
Specialist
Hi @mehboob1011
A Bluetooth transmitter (dongle) perhaps plugged into the Optical, USB or 3.5mm Jack may work. I would start a new thread asking that specific question. Personnaly I wouldn't buy a TV without the A2DP Bluetooth profile so I have no experience or suggestions.
You should note that Sony has never ever included A2DP support for its 7 series TVs but it is included in the higher priced 8(3) series and above. Seems a bit money pinching to me.
OLYMORTON
In Sony language Bluetooth does not mean Bluetooth. I bought Sony stated
Bluetooth for standard Bluetooth enabled vibration headphones for the
impaired ears of mine. Sony might have just said hard luck sucker
Shelly-47
Hi i am having trouble trying to pair wireless headphones to my sony tv via Bluetooth can anyone help me thank you
OLYMORTON
I have two Sony televisions that did not pair. The Sony Bluetooth
specification does not cover headphone use.
