Audio Speaker
Juliedon
Audio Speaker
Hi all
Just bought the Sony Bravia 50X85 Tv and we have a Dennon sound bar.  It keeps switching from audio speakers to tv speakers.  The sound bar is plugged in the HDMI 3 Arc and sync is turned on.
Any ideas?
5 REPLIES 5
royabrown2
Hero
@Juliedon
That’s an eARC capable TV.
So we need to know exactly what model of Denon soundbar you have, and exactly what the spec of the HDMI cable connecting it to the TV is.
As this may need to be a ‘High Speed with Ethernet’ HDMI cable, something the one you are using may or may not be.
Juliedon
Hi, thanks for your reply.  The sound bar is Denon DHT-S316 and I think it’s just a normal HDMI cable, it came with the sound bar.  I will purchase a cable you suggested and will try that.
royabrown2
Hero
@Juliedon
Look on the existing cable. The specification should be printed somewhere along its length, and if it’s already the right sort, will save you buying one.
But anyway, that soundbar is ARC, not eARC, so doesn’t use the Ethernet strand.
Juliedon
We changed the cable but it’s still doing it.  I’ve tried turning the sync off but then all I get is communication error, so had to turn it back on.
HannahEd01
Hey Juliedon, is it the KD-50X85J?
Let's try the basics first:
-Unplug the TV from the mains for two minutes, and disconnect any external device, including the aerial, if you have one.
-Check if your TV is updated: https://www.sony.co.uk/electronics/support/lcd-tvs-android-x85j_x86j_x89j-series/kd-50x85j/software/...
-Follow the relevant steps here: https://helpguide.sony.net/tv/iaep1/v1/en/08-05.html
-Follow these: https://helpguide.sony.net/tv/iaep1/v1/en/08-05_03.html
Let me know how it goes.
