I am a new Sony user - the A7 III and am looking for the right lens and any advice would be appreciated. The lens I’m looking to invest in first will be used in my home to take product photography and flat lays - so I need to be able to stand relatively close to the objects. I have a 50mm lens already.
thank you!
Hi Alicepgy,
I would recommend the SEL24105G lens since it has a wide angle, a short focussing distance, a constant aperture of 4 and gives you lots of flexibility if you would like to do other shots with a longer focal length in future.
https://www.sony.co.uk/electronics/camera-lenses/sel24105g
Cheers
