- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
I have tried it with my Nokia701.And it is not detecting any contact.
I have it on.
And NFC of nokia701 is perfect as i used to use it with some smart tags before.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
might be worth it to repair it with SUS or PCC
Update Service (SUS)
http://www.sonymobile.com/gb/tools/update-service/
http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
Bridge (for Mac)
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
Don't forget the Kudos
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
can you elaborate? are you sure you have both NFC sensors back to back ?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Yes i know the postion of NFC of Nokia701 and even the zr(by the user guide)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
that's quite odd, you should be able to see the sticker on the back on the ZR, does the Nokia work with other phones with NFC?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Yes bro.
I can see the sticker at the back of the Zr.
And yes Nokia NFC works with smarttags and Nokia 808PV and Galaxy s4 and NFC enabled headset before.(just some weeks back) and even lumia phones
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
this might be a dumb question but do the smarttags work with the ZR?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I dont have it any more.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
ok, well is there anything else that you can test your Xperia ZR with?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
No i have to wait till evening to test it with S4,Lumia and smart tags and Z ultra too
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Bridge (for Mac)
