- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Hi ,, I bought C6603 xperia z from about 1 week . I update it and it works great , Sadden I restart my phone today and I dont find Camera icon in lockscreen ??
Can anyone help me to fix this ?
http://i.imgur.com/1O4WKLN.jpg
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
you are the only one that has this problem and from what I can see from your screenshot your home screen has been customised (the battery indicator is none standard) so may I suggest you back up and do a factory reset as I can't think of another way to resolve your issue
on the other hand - I use a pattern on my phone to unlock and never see the standard lockscreen - so perhaps that is the answer
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
have you used a lockscreen editor at some point as by default these buttons cannot be changed as far as I know
You might be able to find an app that will allow you to edit the lockscreen otherwise it looks like a backup and factory reset to return it to normal - you can remove your SD for this process - settings - storage - dismount
also from your picture - that lockscreen does not look like mine - it looks like it's been customised
you could try settings apps - allapps - lock screen, and clear the cache, do at your own risk as I'm not sure what effect this will have, but I guess it won't be any worse
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I never used any application that can edit the lock screen .. and I delete all cache and data from application > all > lockscreen . But still not apear on lock screen . can I fix this issue without factory reset ? It's not easy that I do factory reset everytime this issue come again ! Sony please update..
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
well its simple,goto camera>setting>then quick launch option .THATS IT
