I think that when you access the camera from lock screen, it should close itself after 30 seconds or something like that. Meanwhile in other scenarios (when you open it normally) it should stay on for about 3 minutes .
@Hampus knows the exact details.
Found it :
/t5/Xperia-Z3/Screen-Timeout/m-p/995152#M17630
Found it :
Thank you alexdon and Hampus.
I just have to start the camera from the main menu, not the quick launch button.
For lazy people having the same problem (copypasted from alexdon´s link):
"Hi,
That is correct. If you open the camera with the quick launch button or from the locked screen, it will close automatically after 30 seconds. And if you open it manually without the quick launch button, it will be open for 3 minutes."
Cool,glad we could help.
How do you stop the camera from closing after a few minutes and make it stay open until I decide t close it?
