Battery charging issues
Xmikeaaaa
If the battery is charging with the original cable , the lock screen is telleing fast charging,  but this message is blinking , and the display can't go to sleep. Charging with a normal cable tells charging and I cant turn off the display anymore,  so the battery gets empty while charging.
Additional during charging , all Browsers constantly refreshing themself,  also all the other apps on the phone .
I already tried it to totally reset it , nothing changed . Also cleaned the micro USB of the phone.
Any suggestions ?
Tags (1)
6 REPLIES 6
Uliwooly
@Xmikeaaaa
could you test a different wall charger?
Also, boot in >>> safe mode and report back
RizkyRizz
I never notice that if you charge with original product from sony it will appear fast charging
Can you give the pict of it or video?
Xmikeaaaa
Yeah, I tested it with different chargers.
Safe mode changed anything.
Xmikeaaaa
Herr is the Video :
https://youtu.be/GaigNI0kcyQ
Same issue when battery is full .
On slow loading the screen is just alsways on and don't really charge the phone .
RizkyRizz
Its video of Xperia z2 isnt it?
What actually do you talk about? XPERIA XZ2 or XPERIA Z2?
Xmikeaaaa
It's the Xperia Z2
Model D6503
