I have bought a Sony Xperia XZS and when the battery reaches 15% the graphics become slow and stuttery, so what's happening?
Because ur XZs activated Stamina mode when battery reaches 15% to preserve battery. The feature of Stamina mode is to limit some of the features of ur device including the UI graphic performance.
Hi @Alaa12,
As @eXeon pointed out, this is most likely STAMINA mode that is activating at 15%. You can disable this feature if you go to: Settings > Battery > STAMINA mode > Off.
You can also enable auto-start of STAMINA mode here, just run STAMINA back on then select auto-start at XX%, tap the cogwheel to set at what percentage STAMINA mode will activate.
Let us know if there is anything else you are wondering about.
Thanks a lot guys it was the STAMINA mode, I disabled it and everything went back to normal.
That it great to hear @Alaa12! :smileysmileythumbsup:
Let me know if there is anything else you are wondering about.
