When I activate Screen Saver mode in display settings and start it with "Start now" or waiting for the time out, the screen saver shows for a split second before the screen goes completely black, with the exception of the soft keys showing at the bottom.
There is no Night Mode active.
I have tried a couple of different screen savers with the same result.
I am running Nougat.
Has anyone else experienced this or confirm the behaviour? Is there a fix?
Thanks in advance
my results on XZ are basically the same. 6-7.5 hours of SSM during two days with moderate use, and 5-ish hours of SOT during 3 days with light use, with 10-15% left by the end. Brightness is also about the same level, but constant WiFi or 4G data transfer plus crappy 4G network at home.
I've had a system update since posting this. The problem still presents itself. I have tried a couple of screen savers, Colours and YoWindow.
