Phone won't power on after moving apps to SD card
Ginisamy
Okay so I moved some apps onto my SD card. Then after all apps finished being moved I then turned off my Xperia off. Now it doesn't even turn on anymore. Does this happen to anyone else, or is it just me?  Help?
Got it just under a month ago.
2 REPLIES 2
profile.country.PH.title
MarlonUk1
how did you move the apps?  did you root your device or modified the software?
some apps are not designed to work when moved to sd cards
try to remove your sd card and sim and turn on the device. power button and volume up key at the same time
it it boot loops . chrage it first using the wallmount adapter.for 1-2 hours then software repair using Xperia Companion
Ginisamy
I literally just went into storage and click move apps into SD card, let that finished then turned off my phone.
