Hi I know this option was on my z5 in accessibility settings I think but I can't find it on my xz premium. Is there a setting I can change to enable this on my new phone?
Not with the default system as far as I can tell, I apologise for the inconvenience this causes you.
Hi @Abc10,
The XZ Premium has battery care functionality. What will happen is your phone will charge to ~90% then stop, and charge the last part just before you normally take it off charge.
Based on the information I have available to me, there's no option to enable a notification when charged on this handsets firmware, but it is on Android and one of the great things about Android is you can customise it how you like, so there is likely a third party app on places such as the Google Play Store that should perform this function for you.
Thing is I take my phone off charge when it's 100% so the battery care functionality is no good to me and I didn't want to revert to a third party app is there no way of getting this option back for the xz premium?
