my XZ is not auto-switching from Wifi to Mobile Data
Reetta
Arriving home my XZ switches our home wifi automatically on. Leaving home, XZ does not switch mobile data automatically on. Manually switching to other wifis does not connect, I have to force this to happen by rebooting the device. This means I am rebooting the device several times a day.
What is wrong?
Tags (1)
1 ACCEPTED SOLUTION
profile.country.PH.title
MarlonUk1
settings>wifi>gear icon>auto network switch, is it on?
7 REPLIES 7
MarlonUk1
NeoBeum
Enthusiast
Do you have a VPN or firewall app?
Reetta
was not on, switched it on and will report if makes a difference. It was on originally - might have switched off with Nougat installation.
Reetta
no VPN or Firewall apps. Why? is that something I should have? Vodafone network so pretty sure there was some VPN setup originally (but not an app), but when you go to the VPN network settings, there is nothing there. I do have AVG Protection Pro antivirus app ...
NeoBeum
Enthusiast
VPN and firewall can prevent connectivity if the app isn't set correctly, that's all. You don't need one.
Alessio_841
Contributor
@nolramlb
By default the setting you refer is turned off.
Why you suggest to turn on it? And why by default is turned off (if you say the motivation)?
Thanks!
nugraha
Thanks for the help...
