Massaging problem
Alias633
Massaging problem
I can't send message at all but I can receive messages
1 REPLY 1
ChloeS
Contributor
Hi @Alias633
Welcome to the community!
Sorry to hear about that, I can understand it must be frustrating Slightly_frowning_Face
If you can’t send, but only receive, text messages you might need to set the SMS service center number (SMSC) manually. The SMS service center number is stored on your SIM card and is dependent on your network operator. Contact your network operator for the correct SMS service center number.
To change this try the below:
  1. From your Home screen, tap the Application screen icon.
  2. Find and tap Phone.
  3. If the dialpad does not appear, tap the dialpad icon.
  4. Type *#*#4636#*#*.
  5. Tap Phone information.
  6. Scroll down to SMSC.
  7. Tap Refresh to get the current number and the format it uses. If Refresh error or Update error appears, contact your network operator.
  8. Enter the relevant SMSC number in the input field using the correct format, then tap Update. If Update error appears, contact your network operator.
Let me know how it goes Slightly_smiling_Face
