I have problems with headphones
@Sancito93 wrote:Ogni volta che le collego magari per sentire la musica vanno bene per un paio di minuti dopodiché smette di suonare non so il perché mi aiutate??? Ringrazio anticipatamente chiunque mi risponda Graziee
Quali cuffie? quelle che ha regalato sony in promozione o gli auricolari inclusi nella confezione di vendita?
Anyway, you should translate your question to english 🙂
He has some troubles with the headphones, they work properly for a couple of minutes but then they stop playing music.
I have problems with headphones Every time I connect them to listen to the music it's ok for a couple of minutes then stop playing do not know why help me ??? I thank all those who thank me in advance
No no the headphones are the beats solo 2
Hi @Sancito93,
I have edited your post as this is an English only forum, please make sure you post/reply in English.
Have you tried different headphones, if not could you try a different set and see if you still have the same issue.
Let me know
Nothing
Cable or Bluetooth headset?
