Earphone adapter for playing songs
CRUZEZ
Hi, I bought this phone as a replacement for my mp3 player (fed up carrying two devices daily commute) I have top end Sony headset which has buttons for volume and most importantly skips songs (forward-backward). Again same reasons I don't want to carry headset every day commute. I have nice Sony earphones just bit annoying having to use the phone to skip songs.
I had been searching online for my earphone can't find one all they seem to have a just volume control or mic. I was looking this one but even this don't seem to have buttons. https://www.sonymobile.com/gb/products/accessories/bluetooth-headset-with-speaker-sbh56/
Thanks if you do know adapter/bluetooth I am looking for please help.
1 ACCEPTED SOLUTION
Emir1
Hero
Hi @CRUZEZ!
Do I understand you correctly in that you wish to have the skip song feature with physical buttons? It is possible using the SBH56 which you linked, even though there are no dedicated buttons for it. In order to skip a track forward, double press the Call/Answer button, and to skip to the previous song, press it 3 times.
If you rather want a headset which has dedicated buttons for skipping songs, in addition to volume buttons, then perhaps SBH54 is for you? https://www.sonymobile.com/global-en/products/accessories/stereo-bluetooth-headset-sbh54/
It has physical buttons for all the features you mentioned, such as volume, play/stop and skipping tracks. Slightly_smiling_Face
Did that answer your question?
1 REPLY 1
Emir1
Hero
Hi @CRUZEZ!
