Ld23
Audio problems
The audio system isnt work at all.
There is no calls, no music, nothing at all
3 REPLIES 3
CameronT
Champion
Hi @Ld23, welcome to the community. I am sorry to hear about this.
Do you experience the same issue in safe mode?
Ld23
Yeah, i tried the safr Mode AMD the problem isnt solved, it seems like audio settings has crashed since the Android update
CameronT
Champion
@Ld23,
If the issue started directly after an update, and persists in safe mode, then I recommend you perform a software repair using Xperia Companion on your handset. This will re-install the update.
Make sure you backup using Xperia Companion first.
