Z2, Lollipop update, awful, problems.
nicuu
Hello,
I just updated to Lollipop 5.0 (finally), and now.. the phone is just awful and gives me a headache. It's laggy, it gets stuck, it's slow. I can't find my messages, and I can't even access messages. Can't send or receive, can suddenly get stuck and then get lost in the background (the background only shoves with the colours that change), and it turns off by itself, starts by itself, get message notifications randomly, gets so warm you could probably boil an egg on it.
To sum it up; it's catastrophic. I don't really know what to do, it's just sooooo annoying. Anyone, please help?
159 REPLIES 159
Uliwooly
Could you elaborate on your issue?
did you performed a clean update (deleting all the apps) ?
Theresia1
after upgrading to lollipop my phone get hang, lag and stuck. now it is totally blank. i tried to reset it by push the red button beside simcard slot then turn on again. but it stuck in boot session and cant go to homescreen ( i guess it had bootloop) until now. i also tried to solve with pc companion but usb didnt recognize. what should i do?
mr_xzibit
Contributor
You have an sd card inserted?
dandy63
Leader
Can you let us know specifically what you have done so far......for instance have you tried running it in Safe Mode, tried repairing with PC Companion, fresh install of the update etc etc....
ronfras1
Since the lollipop update I can't switch between care modes I usually use the manual option but it always opens in superior mode and when I try and change ot it crashes and goes back to the home screen.
I have checked for a camera update but nothing there.
Is there anyone else having this trouble or know of a solution?
joferpah
android operating system spends about 30% of the battery
Uliwooly
are you auto updating apps, auto backup on?
mrmann
Is anyone else having this problem! Charges to full pretty quick but goes down very fast when in use even with stamina mode on and half screen brightness. Have using for 1 hour on andoff battery has dropped to 79%!
Tags (1)
Uliwooly
Settings > power managerment > battery > check the 4 top items on the list and how long they were running (hours/minutes) and post the info here, also check the graph and if possible post the screenshots here
TRex2142
Sony suppory reply concerning moving apps to sd
Dear Mohamed,
Thank you for contacting Sony Xperia™ Online Support.
We apologize for the delay in the response. Regarding your inquiry about moving applications to SD card(apk file) to the SD card and not the whole application (obb), we are glad to assist you. Keep in mind that this is a normal behavior in Sony phones and this is not an issue.
Regarding your second inquiry about getting your notifications set, you can go ahead and access to the phone menu by going to Settings>Sound & notifications>Interruptions>In this option you can setup your notifications as you desire.
