z1 compact camera problem
fukaraca
My z1 compact has a problem with the camera. When i take a shot, there's so much yellow dots in the picture. Btw my phone is yellow case. Camera performance is worse than samsung s4 mini but this is 20mp. I dont know whats the problem. And wonder if service will take care of it.
7 REPLIES 7
fukaraca
Any solution or information about it ?
profile.country.RO.title
_alexdon_
If you remove the case,does the same occur?
alexdon
fukaraca
Not much. I dont have another z1c to compare but better than pictures that i captured while case on.
_alexdon_
I think the case causes all the problems.
alexdon
fukaraca
But how can i solve it. They say there is camera problem caused by the case colour but i dont know how to fix it.
_alexdon_
If you remove the case,is it better?
alexdon
Sam
Legend
Legend
Given the above the only solution I can find would be to either use it without the case or modify the size of the hole in the case around the camera lens but that would likely involve damaging the case.
What are your thoughts about this forum? Let us know by doing this short survey.
