Hello to everyone!
I need to change the battery of my Xperia Z1s (C6916). I opened the phone and took off the battery. The battery model is LIS1532ERPC.
It is difficult to get that model in Argentina. I can buy the model named LIS1525ERPC.
Anyone knows the difference between this two? It seems both have the same Voltage, capacity and size.
Thanks in advance!
Ramiro
you should never attempt to repair your phone hardware unless you are a qualified technician, I suggest to contact your local service center for information about genuine xperia parts. Local support
