Xperia neo L Charging Problem
PrashantSharma
Sir,
I am getting problem with charging of my phone. When My phone is fully discharged then if i connect charger to it and the charging starts then it charges my phone in 6-7 Hours and somtimes does not charges.
But earlier my phone gets fully charged within 2- 2.5 hours. The Phone gets warm and heated. My phone is now dead not charging please help me.
Regards ,
Prashant Sharma
9 REPLIES 9
Uliwooly
how are you charging your phone? wall charger or computer? if the later that's normal it will take quite a while to charge the phone, and if you have wifi on or using the phone while charging it through a computer it will take longer
PrashantSharma
I simply charge my phone by connecting a wall charger and my all things like wifi, blutooth and etc are off while charging. I was able to charge my phone in 2-2.5 hours earlier
but now if i connect wall charger it is still discharging while charging
Serious Problem please give a helpfull answer
Regards,
Prashant Sharma
Uliwooly
try a different usb cable and or wall charger, are you using the original Sony's wall charger and Sony's cable?
PrashantSharma
I am using Original Phone , Original Battery , Original Cable and Charger but still not charging.
If i want new original acessories of my phone then from where i will get it
Uliwooly
have you been able to test other cables, chargers? check any sony store for original items
PrashantSharma
When i went to sony Authorised Service Center they said me that the Problem is in the Circiut Board in the Phone.
Uliwooly
I hope they can fix it
Asifneon13
My phone:sony xperia neol L mt25i.I'm having problems with flash light,it flicks when not in airplane mode so I cannot use network while photography.I've tried a lot of things.im very disappointed. I've got a 33 year's old sony television still working fine.i trusted this brand.perhaps Sony no longer has that legendary quality anymore
tattooedjamie
----> Hi everyone. I'm Jamie. I was actually looking for a SONY  Xperia neo L replacement charger, preferrably authentic but I will be willing to grab a non-auth one AS LONG AS IT WORK FOR MY SONY  XPERIA NEO L. I lost the one which my phone originally came in with, that's when I tried using other chargers that would fit into my phone's charging port ( as long as it has a micro USB tip) but none of them worked unfortunately.
I'm thinking the difference is somewhat the same as the wiring difference of an iPhone's data cable which has a total of 5 wires if I'm not mistaken and one of those which fake ones don't have is the reason why an iPhone turns on automatically when connected to it. I'm not sure though.
My question is:
Is it really because XPERIAs work only with XPERIA chargers leaving me with no other choice but to purchase exactly the same type as the one I lost or is it my phone which is defective?
