Will using 2 SIMs instead of 1 affect the battery performance
Michy_Spiky
If i put the second sim .. Will it effect on the battery ? I mean the battery will drain faster than one sim card ? Or it doesn't effect on anything ?
2 REPLIES 2
Emir1
Hero
Hi @Michy_Spiky,
Depending on the network coverage you get the battery performance may be affected slightly just like if you only use a single SIM, but during normal use there shouldn't be a noticeable difference.
Michy_Spiky
Aha here in egypt is 3g and 2g only
