I updated my Xperia Z2 to Android 6.0.1 and now the wifi connecion at work will not work anymore. It tries to connect and finally gives up the ghost and reports Authentication problem. Connection occurs with PEAP method at work, wifi at home using WPA2-PSK works fine.
Someone else reported a similar problem about a month ago for a Z5 (/t5/Xperia-Z5-Z5-Compact-Z5-Premium/Wifi-authentication-problem-after-upgrading-to-Android-6-0/td-p/... but there doesn't seem to be any info on if the problem was solved and how.
Can anyone help me out?
