Whatsapp web connection issue on stand-by.
SoraNoDave
Hi, since the last update 23.4.A.1.232 on my Z3, whatsapp web stopped working correctly. If I keep the phone in stand-by, after 10 minutes or so, the app stop to communicate with the world. That means that I will not recieve any notification about incoming messages unless I turn on the screen. Otherwise, if I use whatsapp only, it works just fine.
Activating the account syncing doesn't change anything, sadly, and I'm not using stamina mode.
This happens both with wi-fi, 2G/3G.
16 REPLIES 16
profile.country.RO.title
_alexdon_
That's strange, you can try to reset stamina like this: first make sure it is disabled, go to settings-apps-all, look for stamina app, force stop and clear data. Restart your device.
But this should not happen if you don't have stamina on.
alexdon
SoraNoDave
Nothing changed resetting the stamina mode /:
Uliwooly
@SoraNoDave
Do you have any other battery apps?
SoraNoDave
Nope.
Uliwooly
@SoraNoDave
settings > about phone > status > signal > what do you see? do  you have any cleanmasters, antivirus, taskillers, data apps?
Uliwooly
@SoraNoDave
also
settings > data usage > whatsapp > have you restricted background data?
SoraNoDave
@uliwooly
Under settings > about phone > status > SIM Status says; Signal strenght: -103dB 1 asu, can't find any settings > about phone > status > signal |:
I don't have any cleanmasters, antivirus, taskillers, data apps or so. Also, background data limitation is not active at all, neither for whatsapp, and my issue happens even on wifi...
Uliwooly
@SoraNoDave
What I would do is repair the phone with PCC
PC Companion (PCC)
Bridge (for Mac)
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
SoraNoDave
@uliwooly
I've done the repair illustrated in this article: http://talk.sonymobile.com/t5/Xperia-Ion/Detailed-Software-Repair-Instructions-using-Pc-Companion-Wi...
Using a new google account, with no configuration keeping, no application exept stocks and whatsapp, and the problem keep existing. So, I think I'm gonna blame 23.4.A.1.232, 'cause this problem popped out after that.
Someone knows how to do a downgrade? (Using PCC, or without freaking out the warranty, I hope) I don't even know which firmware I need to search, 'cause, I think, there was two update in the last two weeks, and I think I'm gonna look for the version previous those two update. Was that 5.0.2? @@
