The 3.5mm input is open because the device is certified as waterproof without any cap. And that small gap you see at the bottom (I think) is the part that lets you attach a hanger.
Yes,that is not recommended. Also,keep it away from salt water.
If you want to be double sure then I have seen owners using duct tape over the flaps
